Is it possible to use 2 BeoLab 11’s with a Moment and BeoLab 3 setup. Can this be done with standard wiring. If possible would the benefits be worth the cost. The use is for music not TV. Thanks
Overkill
I agree. Also, I don't find the 11 and 3s being a very good match. I use my BL3s with one BL11, the 3s connected to the output of the 11 and the 11 to a Core, and to me it sounds like the lowpass filtering in the 11 removes a bit too much for the 3s – it sounds like there is a quieter gap between the lower and the mid bass. I guess thing would be better if a Beovision was used, but based on my experiences I would not recommend the BL3+11 combination for a system without manual control of crossover frequency etc.
...but that's just my personal opinion. others might have better experiences of this combination.
I run 3s and 11 through a surround processor, slightly elevating bass on the 11. Very satisfied with that combination.
Kai
