Use HDMI extractor in my setup
I am working on a way to use airplay 2 from my Apple TV 4 with my speakers without turning the TV on.
My idea is to connect it like this:
I already have most on the components shown on the sketch except the HDMI audio extractor.
There are two use scenarios:
1) Music via airplay: TV is turned off. audio from apple TV is extracted from HDMI and going through powerlink switch to speakers.
2) Video from Apple TV: TV is turned on. Video and audio is passed through to the TV and audio is going from the TV through the powerlink switch to the speakers.
My question is mostly regarding scenario 2, because i have a hard time figuring out the different terms used for these HDMI audio extractors. will it actually work like I wan't it to? Are there something I have to look out for? As I can see some extractors will only work for HDMI ARC
All this just to get the audio signal without activating the V1 ? Why not just connecting the Beolabs to the V1 and switch the picture off after activating the source set for the Apple TV (lets's say DTV) ? You have PICTURE MUTE in the LIST menu of the Beo4. Or even use the AV button on the Beo4 (in the LIST menu) and then activate the source to leave the screen off and activate only the sound (AV then DTV in my example) ?
Hi. The reason for this setup would be to avoid to many remotes and keypresseswhen starting music, and as i allready have most of this setup today (but with a dying Sonos unit for music) I would make the control more complicated if I did what you suggest.
I fully understand the desire for a 'one device' (or even one button) music initiation process, and the setup that you describe seems sensible.
The audio extractor that I use is definitely NOT taking the sound from the ARC (I know this because there can be no ARC along the DVI/HMDI lead to my BV6!)  I use one of these to extract the audio from my ATV4 before then feeding the signal to my BV:
Sounds good. Im not worried about the powerlink switch functionality as that has been used in my current setup for a while.
But do you know if the sound is also transported through the HDMI port to the TV as i would like to use the built in speaker when watching video content from the ATV
I’ll check that later with one of my other TVs
@madskp
Are you using a Beo4 or a BeoRemote One for controlling the V1?
I am using a Beo4.
I just did a test with my Sony TV, and yes it is.  I had the ATV4 sound concurrently (and in sync) from the TV and the A2 Active (connected to the audio extractor's 3.5mm output).
Thank you very much for testing this 🙂 at least now i know this one will do the job
