It must be me,but I can't work out how to add photo's to posts.
Can someone please explain without lapsing into "geekspeak" please?
Thanks,
Nick
Thanks,
Nick
Thanks for all that sir!
As you suggest,it's an excercise in obscurity,but one my poor old noggin could do without!
Regards,
Nick
Once you have made it a few times, it is not that complicated ;-)
It's not even that complicated!
When typing a post there are three tabs - Compose, Options & Preview.
Under the Options tab there is an Add/Update button.
Select that, pick you photo, save ………… and Bob's your aunt's husband!
One thing to note...
Using the Options tab on a regular reply(not a quick reply) will allow you to choose a local file (i.e. a JPG image file) and include it in your post. However, it only allows one image per posting. At least that's all I can get to work.
In a case where you want to place more than one image in your post then the earlier mentioned method of adding images to your Beoworld user folder, then use the Insert Media icon to find those user folder images and use them.
The Beoworld user folder method of storing the images is also more convenient if you plan on using the image over again in multiple posts.
My only wish regarding the images are that the images automatically scaled on the post and allowed for larger image sizes than the current limit. But it isn't that big a deal for me to resize my images for Beoworld...just a minor one 😕
Thanks for the info everyone,I think I've got it sussed now.
Just wait for posts including family photo's(argh!)instead of Beogram's(Beogran's?)etc.
Regards,
Nick
