Carolpa wrote:
Nice work!
If a Beocenter 9500 source is playing on the A6 and you want to extent this source to other products it is possible the A6 in the app says it can't be extended. Then choose the Beocenter 9500 BLC in the app and extent the playing source from here to other products.
You mentioned in another thread that this option to add a primary/secondary Beolink product was possible on the 1. generation of NL products.
My plan is to have BL28 as the main room speaker in the living room where I also have the BC, and add the Beocenter to the BL28 instead as primary Beolink product in the same way as I currently have done with A6, but is that not possible to do?
I’m also not quite familiar with the Beoremote One (still using Beo4/Beolink 5000), but will it be possible to have a “my Button” assigned to e.g. start the Phono source from BC and join it to BL28 with 1 push on the button ?
I must say that it is pretty cool to be able to use a 20 years+ old Beocenter (probably closer to 30 years) in a new Netlink system through an iPhone app, and at the same time being able to use the same system in another room on the old MCL system with a 2 ways Beolink 5000 remote. Well done B&O !
