Upgraded system
We have upgraded our system with the following items bvis 9 and beosound 9000 main room, link rooms have bvis 7-40 bvis 10-46 bvis 8-26 bvis 8-32 beocentre 6-26 and bvis 7-55, and beovision v1, all main tv option 2 and link tvs option 6, all working fine and I can control set top box and listen to cd radio, however in one room bvis 8-32 when I press sat (dtv) I only get the freeview from that tv, do I need to use the link command ? I cant see an option to switch the freeview tuner of. The other strange issue is the bvis 10 I can view set top box and control it but no sound? But if I tune it in turn to tv on channel 1 where I have stored it the I get the sound is there anything I need to change in service menu? all the other tvs are fine
Yes, press LINK - DTV.
You should have only one main tv (videomaster) in a ML setup. All other BVs set to V.OPT 6 (or 5).
Which stb?
How connected?
Main room or directly connected to link BV?
Hope this helps
Stefan
Hey Stefan
I thought might be the case with bvis 8-32, main is option 2 and all other tvs are in option 6, all devices connected to the main tv and all the other tvs are fine its just the one bvis10 that has picture but no sound, however if I go to the channel I tuned i get picture and sound but when I select sat picture but no sound
One more question if you I bought a bv11 which does not have masterlink i take it work be able to view sat , or dvd or listen to the cd or dvd player from the main system even of I have no the ml converter? I can listen to music but not view any sources
