anbody who knows if there is any servicekit for Beo 4, 1710 with pcb and pad?
Regards,
Lars
Regards,
Lars
Yes, I have upgraded my Beo4 to the new "joystick" version.
I would not recommend it if you do not specifically need one of its feature.
P.
P.
Hi Phil,
I was also thinking about if upgrading make sense or not. Could you please let us know which are the new or different features it has.
Thank you
Hi Phil,
do you remember the partno?
/le
A new Beo4 is interesting if you have:
- Have a compatible TV (A TV with a specific menu to activate the new Beo4)
- A MLGW and a home automation system
Thank you Phil,
Interesting. I do have a compatible TV (beovision 10) and I do have a Home Automation System (Lutron Radio RA2, Lutron Sivoia QS curtains) I don't have a MLGW though.
Thanks Phil,
I have a compatible TV, BV 8 and also a Beo 5. If I understand it right I can have the same advantage as a Beo 5.
/le
