Upgrade Beo4
anbody who knows if there is any servicekit for Beo 4, 1710 with pcb and pad?
Regards,
Lars
Yes, I have upgraded my Beo4 to the new "joystick" version.
I would not recommend it if you do not specifically need one of its feature.
P.
P.
Hi Phil,
I was also thinking about if upgrading make sense or not. Could you please let us know which are the new or different features it has.
Thank you
http://www.lintronic.dk/AppNote_BEO4_navi.pdf
Stefan
Hi Phil,
do you remember the partno?
/le
A new Beo4 is interesting if you have:
- Have a compatible TV (A TV with a specific menu to activate the new Beo4)
- A MLGW and a home automation system
Thank you Phil,
Interesting. I do have a compatible TV (beovision 10) and I do have a Home Automation System (Lutron Radio RA2, Lutron Sivoia QS curtains) I don't have a MLGW though.
Thanks Phil,
I have a compatible TV, BV 8 and also a Beo 5. If I understand it right I can have the same advantage as a Beo 5.
/le
