Is it a reasonably straightforward job to update the software chips inside my MX7000 and LX 6000 Beovisions? What are the advantages?
Dave
Dave
I've a Beovision Avant model 8111 which does not recognize the TV and most VRT functions. It's likely that the E-EProm is partly damaged because of flash.
Does anyone know how to get a new programmed prom or a software update to burn a new prom?
The real problem is that TVs contain dangerous voltages even days after they are unplugged, as well as the fact that the fragile CRT neck is in a vulnerable position during servicing.
