Unpacking Beolab 5
74 repliesLocked
Snake,
It may look stupid to you, who cares. I have seen worst, and it's not that bad.
Beside, thanks to these postings I learned where to grab those things... I would have thought twice doing that.
I once received a speaker boxed in a way where the box had to be upside down, in order to facilitate the installation.
Maab wrote:
Snake,
Don't worry Maab, there is no stupid question!
The important for you is to be sure of how to do your installation the best way as possible....We're talking about a 18K€ pair of speakers here!!!
As each BL5 is 61 kg weight, you should ask for a friend's help to be quiet.
Cheers,
KingOfSnake wrote:
Is this post for real?  How to unpack a Beolab 5 box?  Just incredible, or as the French would say, Encroyable.........
There are no stupid questions, only stupid people who dont ask.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
If there was a special way for a Beolab 5 box or any other box to be opened then it would be marked as such.
As each speaker in on a pallet and weighs 65 kgs I just cannot understand why the most simple task needs clarification.
If the post related to the handling of the speaker once unboxed I could appreciate it more - the easiest way to lift these is one hand on the lower edge and one hand under the large rim - one person either side - taking care just to get a grip on the outside edge at the bottom and not to depress the bass cone in any way.  I have lifted these speakers on my own without too much trouble in an emergency anyway.
How about I have a can of Coke, is there a special way to use he ring pull to open it?!?!
I'll get my coat.
Look, with a name like yours I am not surprised that you took the trouble to make such a statement. In person, however, I doubt you would be doing the same...just think about that.
I asked the question because I wanted to be sure to put the boxes in the right position before opening and installing ...by my self! Being impulsive by nature I could have rushed in a mistake that I would have regretted it. It's a simple question that requires a simple answer.
As I said previously I bought in the past speakers that required the box to be put upside down before opening.
I never even touched the bl5 before and by looking at them (excuse me!) they seem not easy to handle without causing damage.
Further, the boxes have so much plastic-wrapping around that I can't see what's written on it.
No one is twisting your arm to force a reply out of your ego.
I apologise if I caused any offence, a question how to open a box makes me laugh.
Your initial question was not about handling the speakers at all - which is understandable - but on opening the box.
I still find it amusing, happy to offer advice on handling them but on opening a box?
Maybe I rely too much on common-sense.
Why did you take the plastic wrapping off without seeking advice first whether it is ok to do so?
Winding you up now, good luck with your new speakers.
For that amount B&O is not taking the effort to unpack?🤔
Good Point Leslie
1) Beolab 5 are not 18000 Euros anyway - or at least nobody I know has paid that for a new pair
2) Unless bought from a pre-owned reseller or private sale the Dealership should have installed
All in jest anyway.
Yeah well, I was just wondering. Have to work now.... (3K/month)🙂
1. Take your watch off your wrist and rings off your fingers. You may also want to consider not wearing a belt while getting the speakers in place. You don't want to scratch the large aluminium platter once you begin.
2. Removing the box is easy to do.
3. The speakers are easy to move. Just do what they do in Struer, or the B&O installer does, roll them along the floor like a beer keg. I've done so many times, even on my wooden floors, without the speakers leaving a mark. Tip them over a bit, and rotate the large aluminium disk with your hands. You don't have to lift the speakers.
4. Fiddle with connections and enjoy.
