Unpacking Beolab 5
Are they in the original boxes?
Hello,
I am staring at those two boxes and I don't know where to start from. Is there a guide how to unpack safely this boxes?
Hi Maab,
Sorry can't help.
But could you please do an unboxing review with photos?
I always love such a post, it makes dream!
Cheers
Yes indeed. They are new in boxes.Eventually I'll figure it out... I just wonder whether the box need to be in a particular position before opening.
I got mine earlier this year. Mine were on pallets. All I had to do was opening the boxes working from the top down to the bottom. No problems at all.
Edward, thanks for your reply but please, don't ask me that.....
I'll have a "big" day tomorrow in moving around some other heavy furniture.
...oh well, I'll see to remember to take a few pics....
Don't worry Maab, I understand!
It's just fun to share such a moment with beofans like us.
About the BL5 boxing, if the 2 boxes are the same as for the Beovision's, you just have to remove the cap of the box and be careful when removing the white polystyrene protection cause it is maintained by 4 vertical tubes that use to stick to it and fall... Hope you understand my explaination.
Of course check if the boxing is in the right side like this 😎
Have a nice BL5 day!
Cheers,
Just open the top ... the rest is self explaining.
There is just one thing: They are really heavy ... 66kg each ... it is better to have a helping hand, when you want to move it from the pallet.
I found it best to get grips to the bigger "plate" of the BL5 ... better don't try to work with the bass cabinet to move them.
Regards
Is this post for real? How to unpack a Beolab 5 box? Just incredible, or as the French would say, Encroyable.........
