Unlocking 3 Rim-Brakes and 3 Transport Screws on Beogram 5000 Turntable
Hi there, please can someone tell me where the 3 rim-brakes and 3 transport screws on the beogram 5000 turntable are located. Souns a stupid question but please help.
David
Lift off the platter and you will find them there.
Section 1 in the user manual ...
To be fair, section 1 is missing on the manual on site!
Thanks Martin, as Peterindicated their is section 1 on the manual I downloaded. I can see the screws and have loosened them. However, I am not sure which are rim brakes, I assume they are three black things attached to the inner platter. I tried to move these but they are not budging. They loo plasticky and I don’t want to break them, please more help here. Thank you. David
Yes, those are the ones. And they can bind a bit.
A wide screwdriver that fits well, and then just turn.
If you are not sure, post a picture.
Thank you again Martin and Peter for your support. I will have a go as instructed. Much appreciated.
David
