UHD with Beovision Avant 55 1st Gen.
I have a SKY Q UHD Receiver and connected it to the HDMI1 Port. The Beovision recognized the UHD Signal correct, but I don't see any differences between Full HD and UHD. The Source is a UHD Source.
When I check the signal information in the service menu, the input resolution is 3840p, but the output resolution is only 1920p.
Can anybody check if this is normal?
thanks
Mirco
Service Menu 1
Hi Mirco,
I read your post and thought I would check what my settings are too
I have 2 4K products
- HDMI 1: Xbox set to 8 bits so it can do the 4K SDR
- HDMI 2: Apple TV 4K
I'll post pictures of what they are
HDMI 1
HDMI 2
How do you acquire the "signal information" display on that TV? Thanks
Its in the customer service menu.
OPTIONS, RED ARROW, GO
@ BeoVox141, Thanks for that. Informative and I now know why I can't tell the difference in PQ on my mate's TV.
His Avant 1 also receiving 4k and displaying 1080p, while on Roku 4k. HDCP is correct at 2.2.
Any ideas?
Hi Aussie Michael,
you have exactly the same problem like me. The AVANT gets 4K Input but only display 1920x1080p. HDCP and HDM1 Connection is correct.
From what I understand the menu is in 1080p
But the image is 4K
That’s what I have been told anyway.
