Mine started failing and I discovered that when I set it down on the tabletop, it failed thereafter. I had to add a thin piece of foam rubber between the batteries and the removable back plate. After a few years that no longer helped, which meant the contacts were loose and getting looser, and finally they pulled completely away from the circuit board. Thus:
1) Be extremely careful about bending the battery contacts -- you don't want the "yoke" portion to move, because it's already probably weakened by the leakage.
2) The remote control can crash and stop working if the batteries go on/off/on/off/etc very rapidly, as they would in a corroded connection. The fix is removing the batteries and connecting the + and - ends of the battery holder with an alligator clip. Then reinsert the batteries and it will work again! For a while...
