Is it possible to connect two sets of 2500's to my beosound4000?? I have located an extra set and their small size could be easily concealed??? What would I need in the way of a Link system in order to do this with the 2500's or say any other B&O speaker???
Any ideas if this is possible at all???
THANX
Two stets of BeoLab2500's
Heya
You can connect the Speakers to the Beosound with this Y-Powerlink Adapter:
Before you do this, remember that two speakers playing the same material in the same room can cause phase problems. The same thing as listening to a mono track through stereo speaker setup. Experimenting with speaker placement may or may not solve that, give it a try and see how it works - for plain background music this rarely is an issue.
Masterlink and a beolink active.
The additional speakers would be located in a seperate room.
Where wouild one purchase the Y cable that was mentioned also how would it work?? Or to put it in laymans terms where would I plug it in???
Also what exactly would I need inorder to get a Master link and beolink active to operate these speakers???
THANX
The Y-adapter (or T-adapter as B&O calls it) isn't what you're looking for. The T-adapter is for connecting multiple speakers together in one room.
If you want the second set of BeoLab 2500s in another room, then a BeoLink Active is what you want. It will 'link' to your Overture with a MasterLink cable (available from B&O stores, but ideally one would be wired to exactly the right length by an installer) and connects to your BeoLab 2500s via PowerLink.
What would be the cost of a B&O Active link set up not includeing the price of the speakers??
I unfortunately am quite a dstance from the store around 4 hours so I would have to think I would be the individual installing the system. Is the systrem a difficult one to installor is it mostly running cableing???
THANX
