hi All,
i have a rather cumbersome (but working) setup today, which is a turntable connected to a preamp, connected to a sonos ZP80 (line in) connected to a Ouverture (aux in) connected to an Eclipse (analogue audio in socket)
i still use tapes and CDs on the Ouverture so don’t want to bypass this completely but all my speakers are connected to the eclipse so am using this with the remote as the control. Unfortunately the Eclipse only has one phono / optical input, otherwise i would connect sonos, ouverture and turntable direct into the TV and all problems solved!
like i say a bit clunky but it works.
however i have a core and was wondering if i can use the turntable connected direct to the line in on this and then “stream” direct to the Eclipse ?
i can’t figure out how to make the core appear as a source on the eclipse as i would have thought that would be the easiest way of doing it ?
any suggestions greatly appreciated as i cant see wood from the trees at mo.
david
