TuneIn not working on Essence mk I
lob4475 wrote:
. But what goes into icecast? I can't just use it as a sort of relay station for an existing stream?
Kind of like whats described here: https://icecast.org/docs/icecast-2.4.1/config-file.html#relay
Sorry if i seem a bit confused.
Oh, sorry for not being more clear about my setup.  It's basically:
HTTPS Internet stream ---> VLC for transcoding  ---> Icecast for rebroadcasting ---> Tunein (with custom URL) on the B&O gear. (With the bold bit happening on my Raspberry pi.)
So VLC is used to bring in the stream from the outside world and convert it into something the B&O gear can understand, but VLC isn't a streamer, just a converter.  So that converted stream is sent to icecast where it is re-streamed/broadcast and then the B&O gear can pick it up.
The icecast relay system you mentioned only works for icecast that you control at both ends - it's basically a mirroring system, it doesn't relay other content.
-Alex
lob4475 wrote:
I've been hit by this problem as well. I mostly use my essence mk1 in the kitchen and suddenly in august sometime i couldn't play my favourite stations (Denmarks Radios stations). I don't know for sure that its related to https and can't figure out exactly how to verify, but one way could be to just try your solution. I do have a qnap nas running at most hours, so i suppose i could install icecast on that? Anyway, any help would be appreciated.
So I may have a no-Rapberry-Pi-Needed solution for you . . .
I found a list of non-TLS URLs (i.e. http, not https) for Danish Radio at https://github.com/jprjr/internet-radio-streams/blob/master/generate_danishradio/
I added the URL for DR P2 as a custom URL in TuneIn (Using the TuneIn app on my phone, since this isn't available through thier web site.)  The URL I added was:
      http://live-icy.gss.dr.dk:8000/A/A04H.mp3
I saved it as a favorite named "DR P2 Direct".  I rebooted my Essence and restarted the app on my phone, and the new "DR P2 Direct" stream showed up and played just fine.
If that doesn't work, try this one:
     http://music.photonmfg.com:8000/DRP2.m3u
This is the same stream being re-streamed by my Raspberry Pi - so probably lower uptime than the official stream, LOL.
Now this is plain weird. Neither of them are working!
I've checked twice. My Essence will still play some other stations, so its working - but it wont accept your custom streams.
Now i am wondering if there is something wrong in my own setup. I can't really see it making a difference, but i'll try a cable directly to the router. I am also wondering if there is anything in the router setup that might have an influence (but again - why would it only impact certain stations?)
I am deeply mystififed...
forgot to write that the custom channels are working fine in the tunein app. They just dont work on the essence
Try this one on the Essence again:
Before I had it restreaming the original DR P2 stream.  Now it is transcoding the audio into a new stream with very simple audio parameters.  Perhaps this will help?  I have been forced to do the same for another station that works on everything but my B&O gear, and this same restreaming configuration makes it work for the B&O gear too.
-Alex
Huh.
This one loads fine in tunein. But I cannot make it a favorite. When I press the heart icon, I get to give it a name, but it does not become a favorite. The heart stays outlined and not “filled”. And when it’s not a favorite, I can’t access it in the Bang &olufsen app (I think it has to be a favorite, I think - unless I’m missing something)
I feel I’m missing something very basic here or maybe just didn’t drink enough coffee.
😁 Ben
My bad. Not enough coffee.
Hadn't realised the stream URL was the same as before and thus already a favorite. I'll let myself out. Sorry.
Trying to make it easy for you, I seem to have made it harder, LOL.
The log files show a number of connections from an IP address in Copenhagen, but all coming from an iPhone.  None of the access attempts from Copenhagen look like a B&O streamer.
The Copenhagen access lines look like this:
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:10 -0700] "GET /DRP2 HTTP/1.1" 200 19283892 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 1202
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:10 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "TuneIn Radio/21.4.1; iPhone13,3; iOS/15.0.1" 0
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:10 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 0
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:41 -0700] "GET /DRP2 HTTP/1.1" 200 550721 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 30
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:42 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "TuneIn Radio/21.4.1; iPhone13,3; iOS/15.0.1" 1
  • 80.167.xxx.xxx - - [06/Oct/2021:23:26:42 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 0
  • 80.167.xxx.xxx - - [06/Oct/2021:23:27:20 -0700] "GET /DRP2 HTTP/1.1" 200 655727 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 37
  • 80.167.xxx.xxx - - [06/Oct/2021:23:27:20 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "TuneIn Radio/21.4.1; iPhone13,3; iOS/15.0.1" 0
  • 80.167.xxx.xxx - - [06/Oct/2021:23:27:20 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "AppleCoreMedia/1.0.0.19A348 (iPhone; U; CPU OS 15_0_1 like Mac OS X; en_gb)" 0
While access from my Moment looks like this:
  • 73.225.x.x - - [07/Oct/2021:00:00:12 -0700] "HEAD /DRP2.m3u HTTP/1.1" 400 365 "-" "-" 0
  • 73.225.x.x - - [07/Oct/2021:00:00:12 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "GStreamer souphttpsrc 1.16.2 libsoup/2.62.3" 0
  • 73.225.x.x - - [07/Oct/2021:00:00:13 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "gvfs/1.24.2" 0
  • 73.225.x.x - - [07/Oct/2021:00:00:13 -0700] "GET /DRP2 HTTP/1.1" 200 43364 "-" "gvfs/1.24.2" 0
  • 73.225.x.x - - [07/Oct/2021:00:00:13 -0700] "HEAD /DRP2 HTTP/1.1" 400 365 "-" "-" 0
And access from my Essence II looks like this:
  • 73.225.x.x - - [06/Oct/2021:23:57:52 -0700] "HEAD /DRP2.m3u HTTP/1.1" 400 365 "-" "-" 0
  • 73.225.x.x - - [06/Oct/2021:23:57:52 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "GStreamer souphttpsrc 1.12.0 libsoup/2.50.0" 0
  • 73.225.x.x - - [06/Oct/2021:23:57:53 -0700] "GET /DRP2.m3u HTTP/1.1" 200 292 "-" "gvfs/1.12.3" 0
  • 73.225.x.x - - [06/Oct/2021:23:57:53 -0700] "GET /DRP2 HTTP/1.1" 200 43364 "-" "gvfs/1.12.3" 0
  • 73.225.x.x - - [06/Oct/2021:23:57:54 -0700] "GET /DRP2 HTTP/1.1" 200 43364 "-" "gvfs/1.12.3" 1
  • 73.225.x.x - - [06/Oct/2021:23:57:54 -0700] "HEAD /DRP2 HTTP/1.1" 400 365 "-" "-" 0
Are you trying to send the stream to your Essence using Airplay?  Or are you using the B&O app to start it directly from the built-in TuneIn on the Essence?
@TWG, If you could include me I appreciate it a lot.
B&O doesn’t have support in Brazil anymore.
Thanks.
Thanks.
Done.
