TuneIn not working on Essence mk I
Is there also problems with TuneIn on Essence mk II?
TuneIn is working fine on my Essence Mk II.
I hope they sort this out for you soon!
-Alex
I have the same issue...reported to BO....solved initially (~2 months ago)....then reapeared.
told them again and still waiting
Very annoying and you can add the fact that timer and alarm not available on MK1.
Unbeliveable that things at this price are not software updated.
Same issue. Looks like Essence I is off the BeoScope for good. Funny how B&O troll this site but won't respond unless the answer is warm and fuzzy. Tune In app works great using the iPhone, and you can use the higher quality stream. Just move on. I did.
@MartinRK, Sorry, my point is that using iOS works fine. Grab an old iDevice and use it exclusively. The Essence is still a great product, its only the line inputs and apps don't work right. If you use it as an airplay hub, it works great and the remote is perfect for on/off and volume control. Hey, we screwed up.
I have received this information about the fix from my dealer:
Resolution
status
Update 14th May: We are working on verifying the solution for this very
unfortunate situation which is caused by a change in the way streams are
handled at our sub-supplier.
We will release a fix for this before the end of May
It is some kind of internal information, when he search for info about the error in their systems
Hopefully they are able to deliver this fix soon
I had to do a factory-reset to start the softwareupdate.
But after selecting one of my favorite stored radiostations in the B&O app it plays some german unkown radiostation? It took some back and forth and some searching within the B&O app to get the right radiostation. But still my stored radiostations doesn't always start when I choose them.
Another thing is that I can't get Deezer working on my Essence mk1. Is this correct? All I get I get is that it can't play that play that song or that it can't be added to the playlist. All the others within the B&O app (M3, M5, Essence mk2 and Moment) work well.
Back to the closet I think? Worst purpose in years as it hasn't worked one day as it should.
