. But what goes into icecast? I can't just use it as a sort of relay station for an existing stream?
Kind of like whats described here: https://icecast.org/docs/icecast-2.4.1/config-file.html#relay
Sorry if i seem a bit confused.
Oh, sorry for not being more clear about my setup. It's basically:
HTTPS Internet stream ---> VLC for transcoding ---> Icecast for rebroadcasting ---> Tunein (with custom URL) on the B&O gear. (With the bold bit happening on my Raspberry pi.)
So VLC is used to bring in the stream from the outside world and convert it into something the B&O gear can understand, but VLC isn't a streamer, just a converter. So that converted stream is sent to icecast where it is re-streamed/broadcast and then the B&O gear can pick it up.
The icecast relay system you mentioned only works for icecast that you control at both ends - it's basically a mirroring system, it doesn't relay other content.
-Alex
