TuneIn not working on Essence mk I
Thx, I also raised the ticket/question there.
Millemissen wrote:
My M3 and the Essence mk2 (latest firmware) don’t appear as CC devices either, even if CC is enabled.
Very strange. Absolutely no problem with the M3 here.
Note: because I have nothing to join to, I don’t use this functionality. This may explain why my M3 works flawlessly !?!
I also have a ChromeCast Audio working as well.
HAWK wrote:
Is there any support address to send them this, so they are aware of the problem? Thx!
You can do that (at least on the iOS version) directly from within the app.
And you can make screenshots there directly to send them, if needed.
In my case, reporting through the app stopped working a while ago, B&O acked and said it should be fixed in a future release. I’m using the web route since and all my tickets are processed.
Regarding CC auth issue, all my devices with CC ver 1.28.102057 are failing (BS1, M5, A6) while devices with CC version 1.44.219548  are woking fine (Core, M3)
My Essence also has the same 1.28.102057 CC version (and is not working anymore).
Interestingly enough my other (Harman Kardon) speakers have 1.44.xxxxxx CC version (and work great) and my Google Home/Nest speakers have 1.50.xxxx and 1.52.xxxx and also work as they should.
BTW, sorry for being off-topic, is there a more suitable thread to discuss the Essence MK2 / Chromecast issues? I posted it in another thread, but that seems very inactive.....
You are right!
I created a new thread
/forum/imported-unmapped/master-control-5500-with-no-volume-control#post-1745388
Could we please carry on this discussion there.
Hi twg,
do you still have the software 4189 with fix for TuneIn on essence mk 1?
br Søren
I do and you've got email.
TWG please send me function SW for essence MK1 ?
