Trouble removing Essence remote to change battery
I have an Essence remote mounted on a desktop plate. I can’t seem to “pull off” the remote from the wall plate in order to change the batteries.Any advice?
You have to slide it off the back plate
To build on Fansastic’s answer, if the Essence is sitting on the table so you can read the “bang & olufsen”, slide it away from you toward the twelve o’clock position.Lawrence
Thank you guys. That helpedB
I like your posts, Barry. Very succinct and practical. Glad to be able to help in a small way.
