Transporting a BeoVision Avant 32
I am considering buying a BeoVision Avant 32 from a private buyer and would like some advice with regards to transporting the TV to its new home.
The seller does not have the original packaging and I only have a large estate car.
Is it OK to transport the TV face down on its screen with several duvets to protect the screen or should it only be transported upright.
All advice greatly appreciated...
Regards
Richard
Absolutely wonderful TV Richard.
I bought mine from Luton, three hours drive from Clitheroe.
I felt it well worth the £40 I spent on renting a transit to keep it upright and well strapped to the sides of the van.
I think you would struggle getting it in any estate car however large.
Andy T.
I have transported 32 Avants a couple of times flat on their faces with no damage although my heart was in my mouth all the time. Couldn't stand the stress nowadays so I hire a transit van for £45 a day and stand them up. Much safer as long as you strap them well!
There is plenty on room in the car (Mercedes E Class Estate).  Did you have the original packaging with yours?  If I buy new packaging from a dealer does anybody know how big it would be in its original packaging and whether it can be transported flat once packed?
Regards
Richard
I remember mine arriving and it is a big box! I doubt it would fit even in an E class and would strongly suggest that upright is the most sensible way. However the most important thing to take is someone else to help lift it!
The packaging is enormous and the set is strapped to a pallet within it. I doubt if it would go in any estate car, E class or otherwise.
It certainly wouldn't go in my discovery with the seats down.
A doctor would say that! 😎
And he did! I do remember the two service engineers struggling in with mine! I confess to not volunteering to help! Sorry boys!
When I used to own an Avant, I moved it myself four times. The first time I had packaging, the last three, none whatsoever. I'd move it upright, strap it tight, but making sure to put soft blankets around the top part of the television, especially the bezel around the screen. No straps should be in direct contact with the Avant. Put on your flashers (hazard lights) and go slow.
Good luck!
-Sal
I've transported an Avant 32 over a distance of 60-odd miles in the back of my E-class - the hydraulic suspension will help a bit, and it'll fit with no problems (as long as it's not in its original packaging, I suspect that'd be a bit tight). If you can, take a few duvets / pillows / WHY to stuff under the middle. Avoid putting any weight on the speaker fret panel. Try to put a bit more under the screen frame as it doesn't quite lie flat with the base circle still on.
 And I might add, this is not my current Avant - I transported this one upright and now the tube is going! Maybe a long lie down is good for them 😁  (although I doubt it)
 I might add, the other day I had a wardrobe in the back of my E-class... over 6' x about 4'.... I nearly haemorrhaged when I remembered the electric closer, just in time to watch it pull the rear window glass to within about 2mm of the corner of the wardrobe....😮
Speaking of which, if anyone needs a hand moving B&o bits, just yell - I'm in South London / Surrey and don't mind mucking in for a fellow lunatic.
