Transportation of BV 7-55
I have just bought a BV 7 55 MK II from 2013 πŸ™‚
I probably have to transport it in the trunk of my car. Is it okay to transport it lying down or should it stand up?
If lying down, should it be on the backside or the front side (screen down)?
The preferred method is standing up, but personally I'd be happy transporting an LCD TV flat if carefully supported and padded.  Watch out for potholes!
I’d have it on the backside - and beware of the blu ray player-part, that it won’t get damaged
It's fine if you're careful; it's only plasma screens that need to be upright when transported.
Thanks for the advises
I will give it a go, and put it on the backside, carefully supported by all kind of soft materials...
Yes. I did the same and it worked fine.
Just be careful with the built in bluray player tray.
I will for sure
