Transmitter1, Beolab 17, Sonos Port and Standby problems, Logs Updated
Hi hi I need some help ?
I just got a lovely setup, with great sound, as can be expected.
Setup: Sonos Port connected via RCA to B&O Transmitter 1 with a wireless connection to 2x Beolab 17 and Beolab 19.
Problem: After some time of non-use 15 + minutes, they the speakers go to sleep or standby
I have to unplug/plug the Transmitter and to be able to get sound again.
I read the WPL_DUMP.txt from the Transmitter
;WPL-TX (svn:5309) Current Settings:
RCA impedance:HIGH
RCA triggerlevel:200
RCA timeout:900
TOSLink timeout:1
RCA and TOSLink gain:-3
ALWAYS ON:FALSE
MULTIPLE PL SOURCES:FALSE
See here Always on: False, can I / should I change it to TRUE ?
Is that OK for the Speakers ?
RCA Timeout ? should I change that ?
Is there Update that I can/should use ?
Here is the Debug LOG:
[00295438]MEMSTICK SW update check starting 00002769 Total 00002769
[00295597]Sense status, PL=0 TOSLINK=0 LINE=1 USBB=0 USBA=1 ATI=0 ALWAYSON=0 TESTMODE=OFF PL/Line Switch=POWERLINK, ASSOCIATED
[00295672]WPL_TX SW updating Speaker 0 Not done
[00295695]WPL_TX SW updating Speaker 1 Not done
[00295714]WPL_TX SW updating Speaker 2 Not done
[00295736]MEMSTICK SW update check completed 00000301 Total 00003070
[00295896]Sense status, PL=0 TOSLINK=0 LINE=1 USBB=0 USBA=0 ATI=0 ALWAYSON=0 TESTMODE=OFF PL/Line Switch=POWERLINK, ASSOCIATED
Need help please
Update.
I did change ALWAYS ON:FALSE  to ALWAYS ON:TRUE
and that seem sto do the trick.
Please comment if you see problem with that ?
BW
Can you describe how you get this debug output and how to change the settings on the Transmitter?
Hi hi
I Live in Iceland, I dont know how many 5 GHz channels we/I have..
any Idea ?
Regarding the Power it just few cents.. so I dont mind, only worried about the speakers.
Is there better way of doing this ?
Hi hi
any Idea ?
