Dear all,
I have a pair of Beolab 20s, which I bought used, and the Toslink input of one of them appears to be broken. The speaker works if I feed it through the 2 analogue RCAs. When using an optical cable it does not work. Plugging the same cable in the same setup into the other speaker works just fine, so I am quite sure that the toslink input is broken (or am I missing something??).
I wanted to ask for help and ideas how I can get life into the beolabs again. I use a Yamaha WXC-50 as a streamer with both coax and toslink digital outputs.
Is there a (digital) cable from coax or toslink into the RJ45 powerlink input? I googled a bit but could not find anything.
Or can I use the toslink in of one speaker (which works) and then connect that speaker through a powerlink to the other one? Or do I need to use toslink throughout if I start the daisychain with toslink?
Would a Beosound Transmitter 1 work, i.e. optical in from my Yamaha and then through WiSA to the speakers? Or is there a cheaper alternative?
If all else fails I just buy a Beosound Core with two Powerlink cables, but it’s just frustrating to spend so much money when my WXC-50 is a pretty decent streamer.
Would appreciate your input! Thanks.
