Too much clash ??
Connect the BeoVision 7 and the BeoSound 3000 with an ML cable to each other.
Connect the speakers to the BeoVision 7, BeoLab 4500 as front speakers and the Beolab 3000 as rear speakers.
Put the BeoVision 7 in option 2 and the BeoSound 3000 in option 0.
Optionally you could buy a BeoLink Passive (T 1656). Connect it with ML to the main room and connect the Redlines to the BeoLink Passive.
Now you can listen to music or watch a DVD in the bedroom.
Right, but you will need a center speaker for the TV.
Marcus
When you say a centre speaker for the TV Marcus, what are you refering to as a requirement ?
Graham.
Hi Graham and welcome to BeoWorld!
A center speaker is the most important speaker in any TV setup. My recommendation would be a BeoLab 7.4, but you may prefer a BeoLab 7.2. Go to your local B&O dealer to see and listen to both of these. They are both very compatible with your BeoVision 7.
Ideally, you'd find your local dealer and ask if their installer(s) can come round and get everything working. B&O kit is not as simple to wire up as other stuff, and you may be missing a few bits & pieces...
