Tip for Moment(Deezer) users
I you want so search for albums from a given label, you can enter the following in the search bar (giving real example to avoid confusion):
label:”impulse” or label:”blue note”
It works also with the Deezer web UI (limited to 300 matches), the Deezer OSX App (limited to 50 matches).
It used to work with the Deezer IOS App, but is failing now
It does not work with the B&O App (I’ll open a case)
Nice find! Now hope for a workaround with the gracenote issue, I really want to use my moodwheel as normal again!
Me too but apparently B&O doesn't want to let me....
