OK.
That is almost 4 hours and ~60 posts.
I will compile my list and place in the blog.
OK.
Its going to take a little bit of getting used to! I like the new look and feel though
I notice that the members username is not displayed above their avatar.! Otherwisw looking good.
Sandy
Yes, I had noticed that as well - I prefer seeing the name as the new avatars are not instantly recognisable.
I would also appear to have an unfeasible amount of stars!! But I can post first time!!
Ok, I guess this is an appropriate place to say it...
I don't mind the lines/sequential lists of gear (swag list as Rich says) but those vertical, bullet-pointed monsters must go!! I maintain a pretty huge list of my gear but it stays in my Bio.
Punch, I'm with you.
Hhhmmm, wasn't this Rich that ever called it a swag list....least I don't think it was.
I rather dig the lists here, at diyaudio, and audiogon. Gives some insight into the member IMHO.
Hi Peter,
It seems that you are the only one with stars... at least you are the only Beta-tester where I can see the three golden stars and the founder-"f"
But I am happy for you that you can post without too much trouble.
edit: Peter, I see you have over 9000 posts already? Must have something to do with the settings
Foxtrott
Can you post directly without using the App??Will try right now on the big iWoop.
BRB
Here I am!
Worked perfectly, as it has for iWoops...
iWoop stolen. 🙁
Android device all that's left. 🙁🙁
I like it. The recent topics list is a little annoying as it makes me forget to go into the actual forum I want.
Also I don't see the need to have general and then general and questions within general.
The speed is excellent as the forum always hung for me when first going to the site.
Its nice to use.
One thing I wonder is when using other forums you get to decide on the theme of the forum so you can view it in which ever mode you prefer.
So far excellent
You will note that the Bronze, Silver Gold logos are not quite working correctly yet, that is work in progress..
