I notice that people with long lists of equipment in their tag line (or what ever it's called) now appear as a vertical list, unnecessarily lengthening a thread - are there plans to change this or do other folk not see it as an annoyance?
Thoughts on the new forum so far?
You mean an annoyance, vertical OR horizontal?
Still can't post from a mobile (android) device unless i use the "html" method .
To be honest I'm not particularly a fan of the "long list of gear" either way but at least when horizontal it doesn't unnecessarily lengthen the thread.
You know the answer to that! 😈
Can you post directly without using the App??
Will try right now on the big iWoop.
BRB
Can you post directly without using the App??Will try right now on the big iWoop.
BRB
Here I am!
BRB
Here I am!
Worked perfectly, as it has for iWoops...
Frankly, I have used the APP, but it is redundant with the latest iOS, IMHO.
I freely post with little and big iWoops all the time.
Only issue I have had is the smiley window not popping, but that is resolved by using the codes...
