Thanks for the diagram and explanation - all is much clearer now 🙂
Looking at option settings for the 'Home' system first:
- BM5/BS5 should be on A.OPT 1 (this should auto configure)
- All five BL3500s should be in L.OPT 6 (including the one in the Townhouse)
- The BV8-32 in the townhouse should be in V.OPT 1 (assuming that it has no connections to either ML system)
Looking at option settings for the 'Townhouse' system:
- BS4 should be in A.OPT 0 (this should auto configure, because no speakers are connected to the BS4's Powerlink sockets)
- BV8-40 should be in V.OPT 2 (so that it processes IR commands for both video and audio)
- The BL3500s should be in L.OPT 6*
- The Passive should be in L.OPT 6*
* However, as previously mentioned the Townhouse BL3500s and Passive, are designed to be used in separate link rooms. Although they may work (switch on, change source and adjust volume), the ML system is not designed to receive the same IR command from a number of sources at once, and this may cause conflicts.
A better solution would be to get rid of the 2 BL2000s in the townhouse, and connect the Passive direct to once of the BV8-40's Powerlink outputs (PL to PL cable required). You could then connect a further Passive and speakers to the BV8-40 for a fuller surround experience.
Furthermore, with the system as it is, how do you know which ML system you are controlling when in the townhouse? Surely when you select a source both the Townhouse and Home systems turn on? Is this not a problem? There is probably a way to solve this latter conflict, but I will wait to hear whether it is indeed a problem. I just re-read one of your earlier posts - you have said that the BL3500 from the main system is in L.OPT 0.
Lastly, I think there may be a way to combine both ML systems (because you can turn OFF the audiomaster function in the BS5) but again I am not sure about this! Have you tried?
