Does any body know if additional boxes are added to the existing list of STB boxes ore some older ones are removed from the list?
Has anybody tried out the 4.01 "Apple remote function" together with a beovision 3?
The complete lists for each chip are now available here on BeoWorld (the gold membership is required to access them).
Roger
Erik,
how do you fast scroll with the apple remote using frontrow in i-tunes? If this would work with the Beo 4 ... perfect!
Thanks.
Ralf
Products / User & Service Manuals / Televisions / Sat Receivers & Accessories / STB-C
hmmm...can't read I just see black bars in the document!
Karsten
I checked the files (pdf), they open normally on my pc.
Do the other pdf-files have the same problem ?
can´t see them with my mac, just bars.....
just like karsten
Same problem here - just black bars on my macbook...
Stefan
No problem here, PC, Adobe Acrobat Reader 7.1.0.
Maybe you need to update the Reader?
Ralf
