Hi Mogelmose,
Yes, this is possible - there are two options for getting surround sound from a Loewe TV (depending on the model of Loewe TV):-
1) Older Loewe TVs have a 26 pin "Audiolink" connector which I can convert to use with Beolab speakers.
2) The 2017 "Bild" TV range has a DAL (Digital Audio Link) socket instead, this needs a DAL to Audiolink converter (which Lee can supply). I can then provide the cabling to convert from this adapter to any combination of Beolab speakers.
If you just want stereo sound from a Loewe TV to one or two Beolab speakers, this is straightforward and we can do this with a simple cable connection.
Please feel free to get in touch via my sponsor link below if you need any further help.
Kind regards, Steve.
That sounds great. This leaves me with one question. Are the volume variable or fixed with the audio link? If it is fixed i need 3 Beolink active also :p
