The Moment software version Release Notes
MicroHH what version have you got?
MicroHH :To your information I have been running the beta version and the last update I got was 2.0.59
Still some bugs but far more stabil
I reported these to beo dealer and got back that they will not correct them in the current version as there will be a complete new firmware this spring
I have the version 2.0.62.
Maybe it is because I called my dealer and asked him to put me on the beta program. Seems that it worked :-)
Okay Last I looked was before Christmas so I might have 2.0.62 available to download.
Does it work better than the old version?
I can only recommend other to join the beta program if possible.
how can we join the beta program?
I got on it because I complained to my dealer and then he got me on the program and since then I have had over 10 upgrades like twice a week.
So put pressure on your dealer is my best advice
Yeah. I did the same.
But I don't have many improvements except of the new interface. What do you mean with the bugfixing? DO we get a complete new Software? Or is this the new Software?
