Millemissen wrote:
Aha - the 'NL/ML Converter Light', that I have been waiting for a couple of years now.....if I understand you right 😕
Please do investigate more, if you can.
MultiRoom will be integration to all products: NL + ML. Means you can use the Moment on more NL products at the same time. And use the same commands on your remotes you are using now for the Moment. Will you have the possibility to listen at different sources with Multiroom? Yes, only with NL products not with ML-products. But thats good news, it means you will have the possibility to use further the ML-link as it is now and integrate the Moment into this link.
The NL/ML converter gets un update to make it possible to distribute the Moments NL sources into the ML, but you will need also a small powerbox to plug into the ML line anywhere, this box will give the necessary current to the ML-link to keep it working in case the old Audiomaster is removed.
I am planning to remove my BS3200 so my Dealer asked B&O,answer was keep the BS3200 momentarely until delivery of that box.
If it really will be necessary to get that box in case you keep the old Audiomaster is a question, could be that the old audiomaster HAS to be removed from the ML-link and replaced by that box. Expect more info in the coming weeks!
