The Moment software version Release Notes
Does anyone know when the new release is supposed to be distributed?
Is the beta release restricted? Like some other Moment 'early adopters' on this forum, I'm getting a "no update available" message when I go to force a software update..
If version number continue to increase on volvocx's Moment, we have no chance to see a distribution soon 😁Does anyone know when the new release is supposed to be distributed?
Yet another increase, now I could update to 2.0.51.2917
Haven't checked it out yet, but version 2 has been more stabil than 1.8 I had.
Noticed that I often have to press like "Radio" tvice on my TV to get feed from Moment.
Taken a Picture of the screen after update.
The beta is not even on radar of the B1´s, so I guess a release is not imminent.
I have sorted out some of the bugs from advice received here:
1) The grey screen after the last SW update was sorted out by a total reset and re-install. Actually had to do it 3x. But now that is sorted.
2) The unresponsive BeoSound Nonsense mkII and remote was due to a new AirPort installed in the next room. A total reset sorted out the interference, but a bit strange that this expensive kit can´t do this in a more dynamic way.
3) The issue of the BeoSound Just-a-Moment panel becoming unresponsive after a few songs still puzzles me. The click sound is heard when you hit "pause", but it will do nothing until you do the paperclip routine. Any tips?
Roger
I asked my dealer to get the BETA Software, but he never heard of a beta for the Moment. Maybe anybody of you has an idea, how to get the beta. I really like this search function.
I´m still on 1.8. After the paperclip reset to get the unresponsive panel up and running again everything was looking ok last night. This morning the panel was again unresponsive (both sides) and the grey screen was back. Hmfr.
As the last family member still using the Just-a-Moment I have now powered it down waiting for the release of the sw 2.0. It worked when I got it, then new sw releases have made it very difficult to live with.
The first piece of kit I have bought from B&O that is close to useless.
Roger
