17 days past the swap of my Jukebox tablet. You remember it got stuck on the B&O logo in doing a reset after receiving a SW update, so B&O decided to swap my Jukebox tablet.
The Moment is now working with the new tablet as it should, its singing as supposed.
Only for that one miserable fault:
Still no possibility to reach the Beoportal servers to check if their is a update.
Every time I push the button to check for an update, It keeps giving me that message: "Software update failed. try again…"
And off course in the about menu the message keeps appearing everyday around 5am: "(date, hour) Not possible to connect to beoportal."
Contacted the dealer, but still no news. And when checking if Beoportal is connected in the Moment’s menu beneath the button ‘About’, it shows me clearly the OK checkmark on the Beoportal connection line.
Another strange thing; Checking the Jukebox data in the ‘About’ menu, it shows the latest software version but there is no serial and no hardware numbered version to find, it just shows 0000000 on both lines.
Any thoughts?
