The Moment software version Release Notes
mbolo01 wrote:
Have you tried the 5s reset while the Jukebox is connected to the SoundHeart? This is the way I usually reset the beast.
Yes, tried so. When placed on the SoundHeart then there is not reset happening at all - no matter if pressing 2 or 5 secs.
EDIT: Interestingly, now that Deezer is back to usual business, the inner circle of the MoodWheel ALSO selects songs that are not in my NAS nor in my Deezer library, too much isn't it?
Does anyone had the same findings?
Strange... Have you tried to look at the streaming info?
Using RPC: http://{server}:9000/rpc/stream_info
My inner circle is working as supposed, see example:
Hi Chris,
how can I check this?
Chris wrote:
Nice tip! I'll be able to better understand the Moment logic while playing from the MoodWheel, particularly the inner ring.
tks Chris
Hi Mirco,
(Use a remote procedure call (RPC) to log in at the Twonky server.) Type your server IP address in the Safari, or Firefox or Chrome address bar... and see what your server is streaming.
http://{server IP}:9000/rpc/stream_info
Some more RPC commands.
Kind regards,
Yann.
 • Twonky NMC Test-Tool     link  and  link
• Twonky DTCP-IP Test
link
• Latest TwonkyServer Status using RPC
link
• See what is currently streaming by using RPC
link
• Set config option using RPC
link
• Rebuild the database using RPC
link
• Clear Cache by using RPC
link
• Show Twonky Config by using RPC
Infected at the age of 13 by a BG 4000 in Dad's Hifi shop.
Tracking with Chris's tip (RPC command) + scanning my Deezer album, I confirm that from time to time, songs that are not part of my libraries are played, sometime a NAS equivalent exist but the song is played out of Deezer, sometime I don't have the song anywhere in my libraries, nor the artist in my Deezer favourites ....
Was the Moment at the dealers? Or was it connected in someone others network?
After a sw fault a dealer reinstalled sw. Connecting the Moment at home, suddenly I had spook devices connected. All were NL apparatuses from his store!
Strange enough it seemed that certain music could be played on the Moment which for sure where not in my collection.
After deleting all the spook NL devices on all NL apparatuses the phenomenon was gone.
Nope, from the box to my living room, and always on my local area network .... I'm not talking about the numerous factory resets.
