The Moment software version Release Notes
it is by using the other menus like e.g. Artist.
And you are sure that the Artists or Playlist you are seeing are from the Twonky server? Not from Deezer?
I would try a power off of the SoundHeart, a hard reset of the JukeBox and a power on to see if it makes the difference
- resetting the library (surprisingly comes back after a few seconds with a check mark).
This intrigues me, it looks as there is not a good 'handshake' between Twonky server and the Moment. (Supposing there is a reasonably stocked music library on the NAS)
If so it could be the server configuration, network conflict, or whatever...
I just checked my software version of the Beosound Moment with the Beotool.
Beosound Moment Jukebox: 1.7.5.1155
Beosound Moment Soundheart: 1.7.399.223963144
Is this version up to date? I wonder, because the version numbers are different.
Greetings,
Mirco
Yes they areIs this version up to date? I wonder, because the version numbers are different.
thanks for the fast answer...
Yes, it says "harvest done" but the content is not accessible thorough the inner ring. However, it is by using the other menus like e.g. Artist.
Exactly the same for me, NAS content is not available on Moodwheel but available in the Artists list.
Sure it is not coming from Deezer, since I have a very limited Deezer collection.
Kind regards,
Yann.
I am now clueless since you other guys are reporting that it works again.
What is strange is that (1) I think most of us had issue with Deezer not DLNA source, for me the inner ring was the only one working (2) without Deezer configured you don't have the DLNA content in your inner ring which in this case of configuration should be the only one active .....
Did you hard reset your JukeBox? not sure I have seen an answer to that
