After yesterdays update it is not possible anymore to change a playlist number by pressing the up-down button on the BEO4, when using only a ML system as the Beolink Passive.
It is only working again when I activate a NL system as my V1 together with the Beolink Passive.
Hi Beroli, Thanks for the info
Just found out that the same occurs with my BL2000, up-down button is not working anymore as long you don't activate a NL product in 'join' mode. No change of music numbers possible with a command of those buttons to the BLC .
But if you use a playlist feeding from Twonky, you can change a music number by pushing the red button for a couple of seconds. Same works for the playlists started from Deezer. If this was also possible before the new update, I never tried it.
Change of radiostations is not possible with the above method, you have to push a number for changing radiostations.
Think it has something to do with the BLC, they must have done a change in software commands after the update for whatever reason. Maybe another setting in my BLC will do the trick. See what happens...
