The Moment software version Release Notes
doublepost
doublepost
doublepost
Sp far I use my Moment as a stand-alone product connected only wirelessly to BL18's, and using Deezer/Tunein as my sources.
I keep seeing comments re. improved search function for Deezer - I think I'm missing something here, as I don't see any search function, improved or otherwise.
Could someone explain please?...
Have you done the upgrade for the Moment?
If you done the update, double tap on music genre in the Deezer (discover) screen. You will get an advanced search screen.
Millemissen wrote:
In order to run a ML-linkproduct in a NL-setup (including the NL/ML Controller) you will need a ML-audio-driver (e.g. an AudioMaster).
Sorry, I guess this reply to me.
To understand it, does this mean that the you cannot run a BL3500 with the Moment without another Beomaster? Or what else can you use as Audiomaster?
I though , and was told, that the NL/ML converter could do the job.
volvoxc wrote:
Millemissen wrote:
In order to run a ML-linkproduct in a NL-setup (including the NL/ML Controller) you will need a ML-audio-driver (e.g. an AudioMaster).MM
In your setup you'll need additionally a Beolink T1611 (discontinued product) or an Almando Masterplay box, until B&o will come with their own new solution (they are working on this)
OK, thanks, even though it was not what I wanted to hear.
Do you have any time frame on this new solution? And is it just a software solution - like an update or does it involve new hardware?
The 1611, I once had such one, think I sold it. How does that help, I understand that it is Power link to Master link converter?
TIP if you are using your own music collection
Add to all track the Artist as well as the ALBUMARTIST. The Moment (and the BeoMusic app) work better.
Today ripped a new cd and I did forget to add the albumartist in the tag.
After an update of the tags with the albumartist the new Album was added to the music collection almost immediately. Where until then the album didn't pop up.
