The Moment software version Release Notes
Noticed a few more tweaks that came with the new release:
- There is now an indication on the moments screen under the song title when you like a song (swiping upwards on the volume wheel)
- The Jukebox wake up faster and have a different indication in the bottom right corner, indicating that connection is being established when I pick the Jukebox up from standby.
- There is now a volume indication in the bottom right corner, when you adjust the volume. Think that was only visible before when you had the speakers connected directly.
do you (or someone else) know how to make Beolab 3500 to work with Moment and other NL products?
One week ago I got a Moment as a replacement of a Beomanster 5, which had been for repair serverel time.
The Beolab 3500 worked fine with with BM3500, but now it is the only ML product in my system.
Beside that, I have 2 Beovision V1 and one Avant 55, and of course a NL/ML converter.
I have tried different settings on the NL/ML, but the BL3500 doesn't turn on, when using the remote.
Any good ideas on how to configure the NL/ML converter?
Is this the 'major' update or will this be in august?
Beroli wrote:
Thank you Beroli.
I have now done the reset, but still have the same problem.. The volume is not responding, and a strange thing is that in the ML source to NL source i don't have the option to set the Beosound Moment to Bluetooth!!
Welcome,
You can find a LOT of information about configuring the BCL in the above posts. Take your time to read and if you have further questions feel free to ask
In order to run a ML-linkproduct in a NL-setup (including the NL/ML Controller) you will need a ML-audio-driver (e.g. an AudioMaster).
Hi there,
got my moment 2 weeks ago. Experience has been mixed but new software is a definitely a step in the right direction.
However, I don't get shuffle to work. From the manual, I understand that you shuffle playlists by tapping them twice.
Everytime I double tap a playlist, it starts playing but always with the first song and just plays them in order of the playlist.
Is anyone experiencing the same issue or are you able to use the shuffle function?
Stefan
doublepost
doublepost
