The MasterLink protocol and opensource
@giovanni,
unfortunately the python code is truncated on the side - is it possible to put the code somewhere I can download it directly?
Hi Frog - Giovanni has uploaded it to GitHub as part of his home assistant integration. I’m currently in the process of translating it for indigo. He did an amazing job reverse engineering the protocol.
his project is here:
my efforts (which have required substantial recoding to python 2.7 as indigo doesn’t support python 3) can be found here. I share it in case your system requires an earlier python version.
link
BTW here is the code for that post above. But do check my github instead, it has much newer code with lots more information.
G.
giac
