Hi all,
anybody out there who has successfully revers-engineered the MasterLink protocol?
I think that there was already an attempt by a Beoworlder in the old forum but did he ever continued his work?
/forum/general-discussion-and-questions/strange-noise-coming-from-beolab-9-and-the-happy-ending
linkJust had an old ML modul from a BeoMedia in my hands and thought about whether somebody could build something compatible.
A ML transceiver without all the BeoLink PC and BeoPort stuff...
You know, just a little PCB that could be attached on and controlled by e.g. a Raspberry Pi.
The engineering part shouldn't be too hard. Just a couple of OP amps, two MUXing ICs and a good DAC with symmetrical output. But a very time consuming project indeed...
Wouldn't that be cool? A diy MLGW + BeoSound system that is highly customizable and opensource for little money...
BR,
BeoMotion.
Current state:
Jun 10 2015 - Inverted logic at the output of the RS485 converter. Need to add a logic inverter.
Jun 7 2015 - RS485 to RS232 converter MAX3280E can be used to read data directly from ML bus
Sep 20 2015 - Tried to send data using a RS485 transceiver. Unsuccessful.
Cheat sheet:
1) Link to old post hooking up a logic analyzer to internal UART of BeoPort: LINK
2) Link to old post where member "psand" describes some details of the telegram: LINK
