Do we know who developed the Beoworld Apple App? As I would have thought this will need repointing to the new forums when thye cut over
The beoworld apple app?
As the forum itself is compatible with safari mobile since iOS 5.0, I don't see any advantage in using the app... Maybe for the small screen of an iPhone, but even there, I prefer to use Safari...
Beware of a closed "app only" Internet! 😐
I really like the Beoworld app. I probably use it more than the browser especially on the iPhone. I hope Philippe is able to do an update.
As long as an app is functionally the same as the browser, I am not worried about an app only internet. Its a convenience nothing more.
Hello Philippe,
I wanted to tell you that I really liked your App.Unfortunately I couldn´t do this with my IPad.Had to go to the PC and start it to tell You :
Please build a new Beoworld App.
Thanks for a wonderful time browsing the old Forum with your App
Ralf
I use the app much more than using Safari. I hope in the next version there will be a search function and a date, when the posts were done.Please update as soon as possible.
Great thanks Philippe, i think there are a number of people using the App from their iPhones on the go
Yes, definitely great App. I used only the App to participate in the discussions of the forum. Really too bad...🙁
Is it possible to use the Tapatalk plugin in the new forum?
I use it with other forums it works great.
Frank
I am currently (literally) working on updating the app. I have just started.
I have tried to contact forum owners but no answer yet :-(
There are still some technical problems to solve with the new forum in general, and I hope you all understand this isn't quite priority A, as the iFolks can nowadays use the forum directly with a browser anyway. I believe you will just have to be patient.
