I have an Essence wall remote in the ensuite bathroom that is configured so that a short press plays the music from the Bedroom Moment and a long press plays the music from the living room Moment.
I was not aware of this possibility.
How do you configure the Essence remote to do that trick?
It's all in the mapping on the NL/ML Converter. Since I rarely use TuneIn, I chose to map the "Radio" function from ML to trigger a "Music" function on the second Moment.
I was more wondering how you can set the remote to do different things dependent on "long press" or "short press".
When in IR mode, a short press on the play button sends the "RADIO" IR command while a long press on the play button send the "CD" IR command. This has always been the case.
FYI, I also tried some of the undocumented "extra" Essence remote modes to try to use an "A.AUX" command, but got strange results.
