The Beosound Moment Beta 2.x thread
Since a few of us have got access to the beta software for 2.x I thought it would make sense to gather views and findings in a separate thread.
Could be good to see whats coming for the exiting users.
I will check with B&O if they are okay with this. If not I will have the thread removed.
Current Beta versions out is 2.0.61 and 2.0.62 as I understood.
A view of 2.0.50 can be found here:
I can add that I am running 2.0.61 on the Moment towards my Synology NAS using the built in DLNA Media Server.
As far as I have tested, it works just fine. Could be that the dependence on Twonky have been relaxed.
Thanks Hiort
To be precise, Jukebox is currently running 2.0.61 and SoundHeart 2.0.444
I'm using Twonky on QNAP and I'll test QNAP DLNA Server in a second phase.
#Deezer
My Deezer collection processing had:
3042 artists
10066 albums
157332 tracks
8 playlists
Where I only have 25 favorite artists set in Deezer.
I hardly explain where the 3042 are coming from, even if they are collected from the Compliation album I may have in Deezer, this number (and the others) are too high IMO with the exception of the playlist number which is accurate.
What are you seeing on your side?
Under the artist tile, the albums are now neatly presented. Under the album tile it looks as in the current version.
mbolo01 wrote:
#Deezer
3042 artists 10066 albums 157332 tracks 8 playlists
I'm not sure where to find that information.
In the configuration mode, the first item is now "Notifications". You may see among the latest notification items something about your Deezer collection processing.
I give my dealer a call to enter my credentials also for the beta
Yes, I saw that when I was updating. Now I just have a long list where it has been checking TuneIn many times.
#MoodWheel
I noticed that while playing tracks through the MoodWheel, the active track is not refreshed in the Playing Queue list screen, instead the first track of the chain stays highlighted. Using the JukeBox wheel to move tracks forward or backward does not change the screen update either and the very first track is still displayed as being the track currently played.
Note: The MoodWheel screen displays the correct artist/track being played on the upper left corner.
This behavior does not exist when playing tracks from the collection screen.
Can you confirm this behavior pls?
