Yes, I can confirm it too.
The Beosound Moment Beta 2.x thread
Login to view image Hiort:Login to view image Lyle Clarke:Version 2.2x solves the error where the JB gets more sluggish over time. I believe those reading the forum that are running 2.2 will be able to confirm this.
Can confirm that. Running beta 2.2.17477
Rock solid
I too would like to know when the beta will be released?
Thanks,
Frank
I would guess that they're close to release either a final version of the current beta or even a general new release. But, that's a guess from my side. I'm currently running beta version 2.2.0.3812-2.2 which solved an issue that I had with my Moment and BLC integration. So looking promising.
When you were having the problems with BLC integration, did you find that you could not access the setup menu when removing the back socket cover?
Yes, exactly that is the problem that I had and the new beta solves this issue. To be able to upgrade you have to reset the SoundHeart so it reboots and once it's up and running again you'll now able to access the Settings menu by removing the lid and go directly for software upgrade.
When you were having the problems with BLC integration, did you find that you could not access the setup menu when removing the back socket cover?Yes, exactly that is the problem that I had and the new beta solves this issue. To be able to upgrade you have to reset the SoundHeart so it reboots and once it's up and running again you'll now able to access the Settings menu by removing the lid and go directly for software upgrade.
Excellent. I did a software update this morning before leaving for work. Fingers are crossed.
How did it go with the update to the latest beta?
Excellent. I did a software update this morning before leaving for work. Fingers are crossed.How did it go with the update to the latest beta?
The new beta seems to be stable and to have fixed the issues. It's nice to finally be able to manually control the DLNA harvesting and to have Deezer FLAC. I can tell a noticeable improvement in sound with the Deezer FLAC. I also notice that the volume control is more responsive and precise.
I overall feel that this beta makes the unit far more snappier and less lag when it comes to handle images.
