The Beosound Moment Beta 2.x thread
Didnt have and Problems to. Everything works fine.
Glad to notice.
Mine worked flawless under the previous 2.2 beta in combination with Deezer HiFi, the ultimate musicsystem for me.
Will see what happens next. I'm convinced that it will be sorted out.
No problems here. I’m on 2.2.18408
I couldn't unterstand, why B&O discontinued the wonderful BS Moment. The device was a disaster the last 2 years, but after Lyle wrote the software complete new, it is one of the best devices for playing music, B&O ever made!
I am very sad, that I will see no new feature anymore.
I hope there's soon a final software version...
It has been confirmed today. My Moment has a hardware faillure.
So, the softwareupdate wasn't the culprit, but an unlucky coincidence.
Beobuddy wrote:
For all the betatesters out there:
Warning! With the latest software released on friday 22th, my Moment lost almost all it's functionality. You will not be able to manually enter the setup menu.
I don't know if I'm the only one, But after downgrading, my Moment works again. I've done this sequence twice (upgrading/downgrading etc) with the same result.
Unless confirmed by B&O otherwise, I would wait with upgrading your software.
Can any other confirm whether the current beta works with Twonky Server v8.5 or not? Asking since I've currentl running with the latest beta being pushed out where they just added some additional log facilities and while upgrading the system to this level I'd also upgrade my Twonky Server installation the QNAP which it seems now that the Moment doesn't support.
Another issue that I currently also have with the current beta is that I can't get into the Settings/Configuration meny by removing the socket cover on the Moment Hub. Tried factory reset and setup the system again with both TuneIn and Deezer (HIFI) and the system seems (I can access Deezer and TuneIn) to work, beside the DLNA-issue and Setting/Configuration issue.
Yes it works
mbolo01 wrote:
Yes it works
Ok, thanks! I've tried to downgrade Twonky Server to version 8.4.1 to see if this would make any difference which it didn't, so back again to version 8.5. So for now I can only wait for B&O to get back to my based on the beta feedback I've provided.
Hi how can I become a beta tester?
I have sent an Email to the address provided in this thread but so far, I have not received a response.
I subscribe to Deezer HIFI and would very much like to have that service enabled on my Beosound Moment.
