Lobster wrote:
Hi mbolo01,
I've still problems to get the artist tiles in the expertmode to work. It worked once after a system reset, but when I put more new tiles in the BEOARTISTS map and after the rescanning of the system all of the "homemade" artist tiles are disappeared and never came back. Also with a total reset of the system. When it worked it was with the softwareversion before the softwareupdate from last friday.
I send B&O also a message about it, but I was curious if it still works with you're system. And maybe you have any clue...?? 😉
Hi Lobster,
This is a issue, I faced too, with the latest Beta. The self-made artist-tiles will reappear, if you do a DLNA-update in the expert tab.
I already informed B&O about this and other things I experienced with the new update. Please do the same and submit a log-file and write a eMail including some screenshots and if possible your BS-Moment-ID and the time, when you submitted the log. With the ID the support is able to find the issue faster and fix it.
With my setup, the previous beta was perfect, now it is a new approach, since some setups with different devices still had some minor issues. I am pretty sure and confident, they will fix it and the 2.2 will be out soon.
Cheers Beroli
