The Beosound Moment Beta 2.x thread
hi
i have a problem with my moment: on the betool app it says beoportal: not ready. When i want to check for software update it says impossible to verify update.
thanks
Back to 2.1 market release! Speakers are ok, no more pshhhhttttttttt, listening to LP through Line-In, all items have a cover (artist or album), harvesting of 35k tracks is complete including Moods .... pur bonheur!
The benefit of the 2.2 adventure is that I introduced my TR1 back in the infrastructure!
BS Moment is wired to it as well as my internet provider player box via SPDIF: I can now share my BL 18/19 between these two devices and stream TV sound, movie sound, Deezer app sound including Lyrics on the screen .... no need for an ECLIPSE :-)
This morning, all of my DLNA content had completely vanished. The Moment had to do another harvesting to get it back. B&O clearly has some work to do to iron out these bugs.
Yep, this is clearly a bug. The way I interpret it based on my observations is the following:
When you start playing DLNA tracks, you may have a native/default playlist on the DLNA server that updates itself to reflect the latest played track or the most played track.
The Moment sees it as a DLNA status change and starts a DLNA rescan, which is useless in this case, and is an endless process, using CPU and network resources which sometimes impacts music streaming flow.
It happens also that instead of doing a simple rescan, the Moment starts a Fullscan which wipes the local DLNA collection on the JB until it is fully rebuilt. When you have a large collection, you clearly see the hit.
If B&O manages to implement a user controlled rescan, then we should see this problem disappear as they cannot control all possible DLNA servers' behavior ( I asked Twonky support if we could envisage a setup where default playlists would be optional, answer is no).
2.2 is supposed to introduce the DLNA expert mode where you can set the DLNA rescan manual.
After hours of harvesting the DLNA collection again, my full 18K songs were restored. JUST TO BE IMMEDIATELY LOST BY ANOTHER HARVESTING that reduced this to only 341 tracks!!! This is absolutely insane that the development team has been silent for months and hasn't fixed this issue.
I just have to laugh when I think of an earlier post that suggested the development team was working on a facial recognition feature. They can't even get the harvesting issue fixed!
Furthermore, it adds insult to injury that the DLNA server is B&O's very own BeoMaster 5. Go right ahead, B&O, and pass the blame on to the maker of the DLNA server! Oh wait, that's YOU, B&O!
For a short moment, I was actually ready to purchase a second Moment for another room. B&O: you're your own worst enemy.
New beta 2.2.0.3722 for the JB is out.
Don‘t know what they‘ve changed.
Experienced the same issues regarding TuneIn-login (shows failed login, but if you skip the login-procedure afterwards, you will see that the login was of course successful.). Missing (greyed out) inner and middle ring on the mood-wheel. New bug in the network-settings: missing wifi quality indicator in the section Soundheart and Jukebox.
Logfile sent.
Deezer-content is snappy and fast available as usual. Volume level is easy to control. Download of Artist-tiles very fast.
Don‘t know, if Deezer is now Deezer hifi.
DLNA not tested.
Cheers Beroli
Logfile sent.
DLNA not tested.
Thanks for sharing.
Will have a look this evening.
Does this update sort out the constant harvesting of your own content?
