... but my DLNA playlists have been easy to manage using the Synology UI, and the Moment has had no issues with them.
My local collection is not huge. 300 albums so roughly 3000 tracks. About 25 local DLNA playlists.
Hi Sandyb,
it really seems to be a issue with larger local collections. Carolpa had no issues with his 20 000. B&O is aware of these issues - but failis to provide a proper recommendation/ a decent manual or their specific test-setup. They just said they test with 40 000.
Could you please answer some questions of mine?
1. Which app do you use to create the playlists on the Synology? AudioStation?
2. How is the order of the playlist-tracks (artists, track01, track02... or scrambled) on the BS-Moment?
3. Is your Synology going into hibernation sometimes (volumes/device). How do you prevent any hibernation?
4. Is there a time lag until your content is accessible?
5. How is your Synology conected to your network?
6. Which device do you use?
7. Does is support Link Aggregation? Do you use Link Aggregation?
8. Have you installed the latest DSM (DSM 6.1.3-15152 Update 1)?
I am asking, because I had to use Twonky, minimServer, Synology to test the betas - but I faced the same troubles with all said Servers. I am to tired to change the setup again and use the device currently as a Deezer-only-Device. In previous DSM-versions the playlist were limited to a small amount of tracks and the were completely mixed-up in their order. Maybe it is now different and I could give it a try again
Cheers Beroli
